Roundabout
- Dec 30, 2008
- 2
I have a 2004 F115 Yamaha on a 1987 Aquasport. The boat and motor were stored for 3 years before being returned to weekly use last October. Motor has only about 25 hours on it. Before starting it up, the fuel sender was removed fromt the tank, the fuel siphoned out so maybe a half gallon was left in the bottom. Tank looked pretty clean from what I could see thru the sender opening. Refueled with fresh 87 octance and Stabil and Ring Free. Changed the spin on fuel filter/separator on the transom with a NAPA Gold 3224 filter/separator. Changed motor oil and lower unit oil. Motor has been running great since being placed back into service.
My question is what else I should be doing to maintain the fuel system so I dont run into the fuel system problems I see on this board and other boards. Till educating myself thru this forum, I did not appreciate the engineering technology of these new outboard motors. My last experience with an outboard was a 1960's two-stroke Johnson.
Any suggestions on keeping this motor running as it should will be greatly appreciated. Is there a better filter choice for the spin-on filter. Are there other filters mounted on the engine that should be changed or cleaned regularly. I have ordered a F115 service manual to help me with servicing and maintaining the motor. I'm a fair backyard mechanic but these motors are a new experience. Thanks again.
