sphelps
- Nov 16, 2011
- 11,490
Yep , I found some 2.5 " pipe laying around .. Kc had a good idea . Only problem is it needs to stay in line and straight ... So I ripped a 1x down to 2.75 " .. Screwed it to the side of the pipe while holding on a flat surface ... . Set the rip fence up to the center of the pipe ... Set the blade just high enough to cut through one side of the pipe ... Make that cut then then turn the whole thing over and rip the other side of the pipe ..Taaadaaa ! pipe split down the middle ... Safely ... I would think I could do that with a full length piece ....
I have a sample full bullnose now cooking ... Maybe tomorrow afternoon it will be dry enough to strip the forms ...
I also have some rounded corners to make .. If I like the bullnose profile I can make a bunch of relief cuts in the half pipe and it should bend around the corners pretty well I think ..
