Finally, the Admiral approved another ship for the fleet. 1976 Starcraft 16' SS
GoldDuster360
Looks like there is plenty of hull left, should clean up nice. Good luck with your project, Super Sports make great little runabouts!
scottmm73
You know, just because you own power tools...doesn't mean you should be allowed to use them.
I'm sure they wondered why the boat leaked.
scottmm73
Got a few hours with the SS this weekend after doing some troubleshooting and maintenance on my UIL's (Uncle in Law) 76 6 hp fisherman. New coils, cleaned and regapped points, cleaned and overhauled carb, and new impeller kit. It hasn't seen any maintenace since he bought it in the early 90's. Backup motor for his setup in Canada, discovered some problems this summer. I digress. So anyways, I was able to clean out the floatation and debris, brushed the corrosion off the transom which has some minor pitting but integrity is still intact. I will follow Watermann's advice and fill with Marine Tex or JB Weld. I was able to cut off the U-bolts which held on the bow post to the trailer and it does seem that it will make a nice fit. Of course I have to weigh the tongue once the boat is put back together.
The trailer will need a bit of work such as replacing the keel rollers, shocks, and adjustments.
The only damage to hull I can see, besides the screws posted above. A minor dent, which you may notice at center.
Port hull looking aft. Hull looks good and bunk looks functional. I may replace with a contemporary marine carpet covered wooden bunk.
Likewise for the starboard hull looking aft.
Mid-keel.
Shocks have seen better days, as well as the springs.
I've decided to mount a great running spare 89 Force 85 hp I have. I've got a lot of spare parts and two powerheads in case something goes wrong. The Johnson needs a lot of work and its something I don't want holding up the (re)float date.
Sometime this week I plan to pressure wash the hull, remove the epoxy and treat with 50/50 vinegar/distilled water than a good rinse off. Hopefully I can get the paint job done before it gets too cold. I will be using WoodOnGlass's tractor paint procedure. We'll see how the funding is when I get to that point.
scottmm73
Well, here I am a few months later finally replying to my original post. As with most lifestyles, life sometimes gets in the way. For me, I'm retired US Army and was finishing my degree so I had plenty of time. I not wanting to waste the tax payer's money, I applied for a position with the Pennsylvania State Park's system and was fortunate enough to be hired. Work has gotten in the way, but each day I am reminded of the project sitting in the back yard.
Demo has been completed and I am hoping to at least get a few hours a week working on her. My next process is to get her metal cleaned and prepped for painting (which, now with a new job, I may subcontract to have done). The trailer, I've discovered, has damage to the left side roller mount frame. I may have to cut that section out and replace, which would require a good welder and therefore another subcontract. In the meantime, I am also moving about a half hour away, closer to my park location. Due to the amount of room, I may have to sell some of the fleet, but both tinnies are staying with me. The Maxum hull may be cut up and hauled away unless some prospective fiberglass aficionado wants to work on her transom and deck.
DLNorth
Being I'm in MN, I'd scrap that trailer and get a decent roller trailer.
I have our SS16 on a 2200 lb Spartian (w/brakes) with the springs reduced to 1600 lb capacity.
Other then that, this brings back memories when ours was apart.
Have fun with it,
Dan
Watermann
Welcome back, we're still here and some of us even have new projects going on. Be sure to pop some pics up for us when you get things going again.
