chuck71449
- Apr 15, 2012
- 9
Ok I have a 1977 135 HP Chrysler I pulled the flywheel to check to see if the key was sheared it was good.
The engine was running at half power wound up being the fuel pump diph and it w
as sucking air around the pump housing .
When I reassy the flywheel it was running great with new diph but I didn't
Get the nut tight enough so it sheared the key I pulled the flywheel again put new key in
Now I'm only getting fire at #2 coil
Any ideas I'm at a loss I don't understand why it was firing before I sheard the key now it not can anyone help me?
