First boat - 1965 ish princecraft GTX
Well "gusset" sounds good to me...hehe
Still to do...............
Glass the pieces to top of gussets.
Finish the bilge area and install drain hole.
Glass floor bow to sturn.
Do some fixing on the underside, a few spots where the outer keels are delaminated.
No Title
Bit more work done.
I cut some more parts and epoxy them in place.
Did some glass, some more on the sides where floor tabs in for extra strength.
Glassed in bilge area, will probably give a second glassing in the bilge.
Still have not install drain, i may go to a 1 inch as it seems to be what is most common for drain plug in local stores.
Checked 5 different places and not one has a 3/4" plug, and only one sales it but has been out for some time and they don't know when they will have more.
No Title
More work done today ( Friday ) .
Second glassing of bilge area.
Installed new drain and plug.
I started on my seat pedestals , 3 of em, 11 x 11 2 pieces each bottom piece has holes for legs,
they will be glassed and the legs will be glassed to the floor, will pre drill holes for the swivels so they will be sealed.
No Title
Hi. I got a lot done today (Saturday).
Floor is now fully glassed, so is the transom brace.
Also glassed the gunwales .
Seat pedestals epoxy-ed on both sides.
Also i drilled holes for navigation lights.
now for some pics.
kcassells
Het slow down you're making me look bad! BTW... hang the canoe in the garage now.
Looking good from here.
No Title
More progress. I glassed the pedestals to deck.
pre drill holes for hardware.
2 rod holders per side to keep em out of the way when not in use.
started on the paint.
No Title
Well i am not sure i want to do this again, it is hard work.
Hoping to enjoy this thing as much as i can for the last month of summer.
September can be cold around here.
sphelps
Looks like you will be ready to wet a line pretty soon ! I've never seen a seat pedestal made like that before .. I like the idea .. Only concern would be lateral movement maybe .. If it ever did start to wiggle back and forth you could glass in some little triangle pieces underneath where the post meets the bottom of the plywood ... Nice work !!
No Title
Yup i just made some simple stools and put a swivel seat on it.
Well first day out was good, boat floats ( nice and flat).
Need a better outboard, it is powerful enough but is very hard to start as in you need big muscles.
So here are the pics of my day out whit my new-ish old boat.
No Title
sphelps, i just now got what you are saying about the seat base.
I made them out of 2 pieces of 1/2 '' glued together, the one on the bottom has 1'' hole that the post goes in to,
so the post is epoxy to both pieces of 1/2'' just like a chair leg, it goes in to the seat it self. as for on the floor,
i used some thickene[FONT=arial, sans-serif]d[/FONT] epoxy and also glassed in the bottom end of leg.
kcassells, yup it sure is satisfying to enjoy this thing after all the work i did to get it to this point,
and also the fact she had as much fun as i did makes it that much more worth the work.
also have 7 grand kids that will what to go out whit me in this thing, so i am glad it turned out
to be very stable on the water even in choppy conditions.
