JimS123
- Jul 27, 2007
- 8,259
It has 2 thru transom bolts and 2 clamps for the top. It's not just a clamp on engine.
You have clamps and 2 bolt holes for security. That is what I would refer to as a clamp on motor. It is not adjustable.
A bolt on motor is one with no clamps at all, and a series of 5 vertical bolt holes to enable adjustment. All just semantics.
They key to this dilemma is using the correct prop that will provide the correct wot rpm. When a boat is run near the top end of the max weight requirement, a pitch lower than std would probably be required.
