boatmon345
- Apr 26, 2006
- 113
Rebuilding 1997 Yamaha 150HP 2 stroke Saltwater Series II S150TXRV powerhead.<br />( Click here to view updated blog with new pictures )<br /><br />I got the heads installed this evening and ran a compression test (without the intake and carbs on, but I did add some extra lube in through the spark plug holes).<br /><br />Results:<br />Port Top 120 Stbd Top 117<br />Port Middle 119 Stbd Middle 115<br />Port Bottom 118 Stbd Bottom 110 <br /><br />(oversize piston in cylinder: Stbd Bottom)<br /><br />I measured Port first.<br /><br />I ran the test a second time and some of the readings were up to 5 pounds lower.<br /><br />I am unable to find compression specs in my book.<br /><br />Two questions:<br />1. Are these compression results proper for my engine? Where can I find specs for my eng...<br /><br />2. Stbd Bottom has the lowest compression. Could this be because the head was burred (or deburred, not sure of the correct terminology) and therefore there is more space for the gases to compress resulting in lower pressure?
