- Apr 17, 2002
- 71,241
Re: First engine rebuild
Ayuh,... Everybodyelse has pretty well covered most what what I see wrong,...
Bearing, crank, block-wise...
The water you found is condensate,... Forget about it....
Take the complete short block assembley, 'n the heads to the Machine Shop of your choice,...
They can do the total, final disassembley, boil the salvageable parts, 'n tell ya what you need for a usually reasonable price....
Then get Friendly with the guy doin' the work......
This would be the perfect time to consider a stroker crank kit, 'n Vortec heads,...
A Kit, a .030" overbore, 'n new pistons is a 383"er....
Theres some spots with water in the oil but the oil I drained out has been sitting in a clear bucket since last night and I dont see any water in it. The places I found water were a tiny bit in the sludge in the bottom of the oil pan and in a couple of the valleys on the heads under the valve covers.
No water in the oil that was in the intake valley.
Basically, you have a Rebuildable core motor,...I already bought a new complete engine for my boat a few months ago. this is just a project I want to do as a learning experience.
