Franco_boater
- Nov 2, 2021
- 131
Ciao,
I am planning to do my 1st bellow job on my 2007 boat, I am owner for 8 years and I want to replace my bellows just as a precaution.
I have all the tools and OEM parts, i will replace shift cable and trim senders too,
I need to replace gear oil hose and also there is a water hose in the kit, i read on the forum some posts by Chris its not recommended to do that, why?
Do I need to run the tap after removing the shift cable nut? I have 1/4 x 18 NPSF HSS Tap,
I read also problem when installing exhaust bellows, should I use bellow adhesive as per manual?? Wont it slide off? Thanks
Thanks any advice is appreciated!
