As per my earlier thread I decided to do a tune up on my Prestolite points style dist.
I am trying to fix some issues on a new engine I have. It has 22 hours on it right now. It will run good then it will start backfiring and bogging at anything over 2K RPM.
I have had a problem even when it is running good where it will bog when the secondaries open.
Here is what I got today.
This is my first time dealing with a carb or points IGN so bear with me please. You guys have been a life saver in all this.
I read the how to on points in the FAQ and I read up in other places too.
I bought a tune up kit (points, condenser, rotor, and cap) for my dist. I also bought a digital timing light that tells you the RPMs too and it has an "advance" feature which I have no idea what it is.
Per manual for my engine. Timing at idle (650RPM) 8 BTDC, Point gap .0018
Dwell, 27-31
Before I took the points out of the old dist I checked the timing. It was right at 8 BTDC. I also checked the gap on the old points when the points were opened and I couldn't even get the .0018 feeler in there. The looked nearly closed.
I replaced all of the tune up stuff in the dist. After some trial and error I got the points right on to 29 with the dwell meter which is half of the 27-31 it says in the manual.
After I did that I hooked up the timing light and the timing had moved to 15 BTDC.
It was getting dark then so I packed up and will fininsh tom.
Questions about this:
Where is the mechanical advance? How do I check it and fix or replace it?
Does what I have described above sound right? Timing went from 8 to 15 degrees? If it is right then my old points and dwell must have been way off right?
Pic of my dist. I already took the condenser out.
Now about the carb. I have been having problems with the bogging when the secondaries open.
I just pumped all the gas out of the tank and inspected the tank and filled it back up about 1/2 full with fresh gas and some Stabil. also installed a new fuel/water sep filter.
I took the boat out today for about 30 mins to check it out after replacing the gas. I took the flame arrestor off while my girl drove and I manually operated the secondaries from the carb.
The secondaries DO open all the way and the air butterflies DO open also.
BUT... When I had the thing wide open with the secondary butterflies open all the way, the primary jets (both the big ones on top and the very small ones under the air butterflies) had a TON of fuel coming out of them.
On the secondaries though the very small jets that are under the air butterflies were spraying a bunch but the big butterflies on top were squirting next to nothing. I mean really nothing. Barely anything just 1 percent of what the primary ones were.
Is this normal? If not what could be wrong? Could this be the cause of my bogging at WOT and what do I do to fix it? Adjustment?
Also look at this video I took today. I am not sure if this choke was this way before but I think it was not. If I remember right the bar on the side would close the choke plate if you moved it. Now it just moves up and down and doesn't cause the choke plate to move.
Look wrong or broke to you guys? If this choke is broke or not working what kind of problems could this cause?
http://www.youtube.com/watch?v=8_SMqUV9V48
Thanks again everyone. I really really appreciate it!!!
Dwell, 27-31
