dingbat
- Nov 20, 2001
- 17,094
Re: Fishing reel lubricants?
Generally speaking, Grease on gears and oil on bearings and keep the quantities of both to a minimum.<br /><br />GREASE: Main Gear, Pinion Gear, Pinion Yoke, Worm Shaft (light grease), Worm Gear, Release Slider, Worm Shaft Guard, Anti-Reverse ratchet (when applicable), Continuous Anti-reverse clutch sleeve (when applicable)<br /><br />OIL: Spool Shaft, Spool Shaft ends, Handle Knobs (both sides), Spool Release Mechanism, Level Wind Stabilizer Bar, Ball Bearings.<br /><br /><br />The products I use are Super Lube synthetic grease and Abu rocket oil.<br /><br />
<br />
