Fixed mount VHF with built-in GPS/DSC...and mic on the right?
ajgraz
Anyone know of a fixed-mount VHF radio with built-in GPS/DSC (like the Standard Horizon GX1700), but with the mic on the right-hand side of the face? (Or, I suppose, that you could plug the supplied mic--not a "special remote function extra $$$" mic--into the back of the unit). Would be more convenient than a left-hand side of the face mounting for the way I want to arrange my stuff.
Both Icom and Cobra had some right-side mics, but none I found with the built-in GPS I was looking for. I want to avoid mounting a separate GPS antenna.
(Not interested in the "black-box" type where you mount the body hidden away and run the mic to your dashboard or wherever--not that I could find one with built-in GPS anyway!)
(Also, does not necessarily have to be the most "current" model, maybe I could find a used one)
alldodge
Here is a few
http://www.iboats.com/Uniden-UM380-...6378680--session_id.856722106--view_id.736906
http://www.iboats.com/Uniden-UM380-...6378680--session_id.856722106--view_id.736855
These have it but just doesn't mention GPS, but note position info
http://www.iboats.com/Cobra-MR45-D-...6378680--session_id.856722106--view_id.733288
http://www.iboats.com/Uniden-UM415-...6378680--session_id.856722106--view_id.705306
http://www.iboats.com/Uniden-UM415-...6378680--session_id.856722106--view_id.704995
If it has a distress call key, it has GPS function interface
Note : you need a GPS to tie into these
Radios like the Icom M324G has a built in GPS
To use the auto distress you need to obtain an MMSI number. Maybe more info then you wanted, maybe not enough, :noidea:
