I have 1980 E35ECSM that has locked up over winter storage. I Thought at first that the battery is dead as the engine did not spin and hurried to buy a new one. Only after that I did realize that the flywheel will not move a fraction of degree. I took the lower unit out, and it spins. The flywheel stays locked.
I sprayed some CRC in cylinders and have some hopes to get engine rotating again, but what sort of repais should I be looking at even if I get it freed? Nothing but more oil at first?
Meanwhile ... took the thermostat cover out and managed to break some of its bolts into the head. Hope it comes tight again still, but I am also afraid that most of the bolts will no longer secure into the old threads. I am afraid I will have to take the head to a shop, but it seems that I cannot get the cylinder head out without removing the whole block because of limited access. Or should all of the head bolts be accessible?
