Re: Fixing Blisters? What's the best way?
Doing a search using "blisters" should provide many posts.
Blisters are normally just a cosmetic issue, so the good news is you don't need to do anything before using the boat. The bad news is that a true blister repair can be time consuming and costly.
If you only have blisters in a small area (2'X2' is small), then most likely this is just a defect in that area. It may be a poorly done repair, or a problem just in that spot when the hull was being made. There is a possibility that this only the start of a problem though.
I'd wait and see if the blisters spread, if they do then anything you would have done right now would be a waste of time. If over time they stay confined to the current area, then you can do the repair and be confident you got it all. If they do spread then you need to decide if its worth it to you for the cost involved.
The repair can be done with epoxy or VE resin, you need to grind out the entire area, fill the blisters, laminate at least a couple of layers of glass down, fair the surface, then paint. The same steps would be needed to do the entire hull if the whole thing blisters.
