flat line trolling for trout
film495
have a local resevoir, Northeast USA, think it is about 350 acres, half of it is shallow, 10 feet or less with islands and a lot of structure, and the other half has a dam at the end, and is mostly 20 feet deep, with a 30 foot deep section, that goes to 34 I think is the deepest part.
we troll the 3.5" floating Rapalas, and I've had luck with that on other lakes. I've tried Rapala plugs that go 10 feet deep, but they are countdowns, and they are pricey - and I lost one on the first day, reeled the snap swivel into the rod guide, and I saw fish following it when I reeled in, and I tried to cast out again quick to maybe get lucky, and it snapped on the knot to the snap swivel. I think I'm going to just start always putting a red bead on top of my swivel, and using a flourocarbon leader of 12-24 inches, at least, regardless of rigging, so I don't keep reeling the rigging into the tip of the rod. those ones don't float, so - going to look for it was not an option. I got some other plugs that are Rapala and go 20 feet deep. I think just by looking at a depth map, and getting some bearings from the shoreline, I can make some deeper runs through that area, not that I know that technique or those plugs will work, still going trial and error, and have caught a bunch of stuff, but I'm targeting the Rainbow Trout they stock, but have yet to see one, so - no imperical evidence they are even actually in the lake. Think we hooked up with a few, but they came off and we didn't get eyes on them, so - they could have been bass easy enough. I picked up a 2lb bass trolling a 10 foot deep rapala Yellow Perch imitation. I got them with the intention to pick up Trout, but I've picked up good size bass trolling like that before on other lakes, so - I'm doing somethings not completely wrong.
What rigging do you use to troll for trout? I picked up some 3 way swivels, so I can try to run the floating plugs a bit deeper, but - hard to tell how deep it is or isn't. We also don't have rods that tell you how much line you have out, so - we're just kind of ballparking that, 100-200 feet back is most likely, just by eye.
trying to figure out a formula to flat line different depths with different lures. The plugs are relatively easy, but spoons and spinners and such, like if I want to put that at 5, 10, 15, 20, 25 feet, to be at different depths, anyone have a good flatline rigging they use to do that kind of thing? or if I want to add a weight to the rigging and run one of the floating 3.5 inch Raplas 5 feet deeper, I think I'd need to know what weight to use and how far back with greater accuracy. I assume I'll need a rod with a line counter, but I don't know. I'm just using a 20 year old Zebco closed face reel, I grabbed many moons ago and found up at the camp, and it seems fine for how I'm using it, but a line counter would be a benefit or so I would think.
I've had most of my luck with Trout, trolling the 3.5 inch floating Rapalas, but kind of fast 3.5-4mph, and I don't know if that is an indicator that fast is better, or if getting them a bit deeper is why going faster has worked historically for me. So, theory being, if I added a bit of weigh to the rigging, and slowed down to 2 - 2.5 mph, I might get more hookups, especially if they aren't up on top.
I played around with slip bobbers for casting, and rigging a jig and worm, and that seems like it will work to cast and cover a variety of depths and area relatively quickly. Will I have to get that jig right down on the bottom, or will a Trout take it if it is suspended. I don't really care if I lose some of the jigs, the leader would be 8lb flourocarbon, and the main line 10 lb clear Mono. so, If I get hung up, the leader should pop first.
aspeck
If you want to be that precise with depth you will need a downrigger or a dipsey diver. I have had the best luck targeting trout with spoons and spinners and smaller baits than I use for bass the same size.
film495
I played with a three way rig and like how it works well enough. It isn't an exact science, but certainly down to 20 or 30 feet, it will get you there without too much trouble. Going slow enough is the challenge.
jimmyu
I’m not sure here but if you’re flat line trolling then aren’t you just conceding to trolling top water?? If your not gonna use lead core line then I would just go with a three-way swivel. Maybe try some real big krocodile lures. Rapala makes some good sinking lures too; not all of them are floating or countdowns. I love trolling with lead core line though. As using needle fish on that.
dingbat
I use a spreadsheet that relates weight, line diameter and boat speed to depth. Use a combination of weight and speed to obtain a given depth.
Most trolling lures are designed to run x deep at speed X. Use weight to adjust depth the lure runs.
Run mono on a couple of rigs to troll top water. Everything else runs braid. Multi-year use. Far less weight to obtain a given depth.
Not a fan of hardware. Use wind-on leaders. Use black hardware if absolutely nessacary.
I start out trolling at a given speed. If I don’t get a pull, I start varying speed up and down until I do. Have seen the “best” speed vary from 2 to 4 kts in a given day.
Boat traffic will push fish down and away Planers boards and stick baits are deadly on trout.
rolmops
Your fishing grounds sound a lot like Central Massachusetts
You should start with water temperature at the different depths and knowledge about underwater springs. Trout are very sensitive to temperatures and a degree more or less is often crucial. In winter check out where the warmest water is and fish there. Also , reservoir trout is often quite small and instead of rapala you should try Mepps deep running spinners (willow leaf shaped) or rooster tails. Since it is trout you're after, instead of trolling, cast the spinners and bring them in with jerky movements allowing the lure to sink and then come up in the water.
The water around springs is usually a bit warmer, so specially in winter, that is where you find the fish.
In shallow water like this, the bass that you mentioned usually make short work of the naive stocked trout. You may be chasing phantoms unless you fish just a few days after the trout has been released into the reservoir.
rolmops
There is one thing I forgot to mention. That is trout feeding habits.
Usually rainbows feed on bugs and small stuff like that. It is only when they reach about 20 inches that they will start feeding on small fish. Although there is of course a transition period. Once they change their diet to small fish, they can be caught with lures like rapalas.
rolmops
Obvious joke .... fish .....schools , yeah?😄.........nah?😐........:LOL:
The joke was not on the fish ,but on me. What I meant to say is that we may have great theories on animal behavior in general and even write books about it. In the end however, these animals are always full of surprises and very often behave quite differently from what they are "supposed "to behave like. Hence my comment that they don't know how to read.
film495
I've had good luck this spring with the Rapalas, just trolled behind a little rowboat. Faster seems to work a little better, probably 3-3.5 mph .. and I never did it before in a river, but same technique got a bunch of rainbows from a local river, was very productive. Going both ways, just the same as in a lake. Upstream and downstream seemed to work about the same, I was anticipating on a river, having to back troll, or do some complicated technique, but - seemed to work fine out of the box. the size 9 I think 3.5 inches, original floating. just the original minnow pattern seemed to be the best for me this spring, followed by the rainbow pattern ... mostly catching rainbows
cyclops222
When you drag it past a hungry fish ?
Fish on !!!
I have casted and trolled over fish ALL feeding on a animal or insect just below the bottom surface. I motored slowly over the Small Mouth Bass school. All sizes together. Not 1 even moved slightly as I moved over the huge school. Only had that happen 1 time in my life. No lure would distract them.
Just like trout requiring a ....Match the hatch..... routine.
Mc Tool
Every few years we get a Beach mast ( beach trees flower and go to seed ) which provides a banquet for mice and their population explodes . Trout , big ones gorge on the mice and a floating mouse lure gets good results.
