Re: Flo-torq II and XHS hub users.....
ajc 1219. Yes to your backoff question.
Think about it guys and gals, what's this clutch dog hootus in there for in the first place.
Well your prop is a gear tied to your engine. Water is a semisolid and at high speeds is more like a solid
cause it is till you move it out of the way; it doesn't compress. d
So when you are at WOT and dump the throttle, if there wasn't a slip clutch of some sort the prop would attempt to follow the engines rpm and try to shut down (from 5000 rpm to 700 engine rpm's) in as short a time as it could get the water out of it's way.
For the boat and it's occupants this could be like running your car into a brick wall.....had it happen on an engine siezure once and you can't believe how fast your boat will stop when you freeze the prop at WOT.
So early designers put in the slip clutch, spring loaded so that it will engage when required and disengage any time the engine is going slower than the prop.....in Forward gear that is; not used in Reverse....at least not on Mercs.
Most of the time you don't hear it clattering when slowing down (usually too many other things making noise that masks it) but you said you heard it.....interesting cause it's there and rattles every time you slow your boat........so the gears must be designed to tolerate it. Right? d
So apparently what happens, with out new high performance, heavy, high pitched, high raked, multi-bladed props of current design, is the combination of weight and increased turbulence at low speed (idle in particular and particularly on engines with few cylinders) we get
pulsating torque differences between the prop shaft, prop, and drive shaft that cause the clutch to get pushed and pulled on and
causes the dog to slip and catch and slip and catch, which is the rattle.
If the hub to propshaft interface is loose (requirement for the 100 ft-lbs of torque on the nut) then that would be an additional slop which could cause noise of it's own and also could add to the instability applied to the clutch dog resulting in more intense rattling.
Phew My 2c.
Mark
