AaronWhitt82
- Sep 22, 2007
- 54
Re: Floats on Holley 4BBL Carb.
Yea sorry I meant to exclude the fuel bowl gasket. I know what that is for, but that is how the pic showed it.
I still don't know why the primary had the other gasket with the larger opening on there and I'm not sure if it's ever been rebuilt before I bought the boat or if the gasket is stock from factory.
I'm getting to the point where I'm ready to throw this thing in the trash LOL
Not many moving parts on them, but plenty of gaskets and alot of tuning BS and I just can't seem to get it right!!!
I am pretty mechanically inclined, but carb's are newer to me..... First thing I've bought that has a Holley on it. I'm used to fuel injection.
I want to say that mine does have the pump lever at the rear of the carb as well.
This carb is not new. Came stock on this boat in 99 from Indmar. I don't know the history of it or if it has been rebuilt or had any work done to it.
the one on the left is between body and metering plate- see the small hole above the large cavity? Use the one with the small hole. That is for the accell pump. The skinny gasket goes between the plate, and the float body.
The reason I ask to see other side of carb is- does your's have the pump lever at the back (secondaries) of the carb.
I seem to remember that the sec pump was always on the starter side. Is this carb new to you, or some-one else installed it?
