JASinIL2006
- Feb 10, 2012
- 5,737
All the foam should come out, usually by hacking into chunks. A claw hammer works well. Also, stringers run from the front of the boat to the back.
Not to disagree. I preffered the wire wheel and shop vac for foam removal. To me it is much quicker and alot less work,
A=plywood
B=stringer
C=floor
D=plywood
Does that look correct? All is covered in fiberglass so that sucks cause its all bad. Removing foam is not fun but a lot came out with a shovel. How much is foam anyway? I was surprised to find water at the bottom and in the foam.
Yes, outdrive comes out first. A chain hoist on the rafters is great if the rafters are up to the task.
Thanks for the info guys. In the link below is some of the videos I have been watching to better understand what to do I thought this guy did an excellent job explaining everything
https://youtu.be/WC3P9lTVzds
