floor glassing question
KCKracker
Re: floor glassing question
i called everywhere and not find any cabosil locally. i thought i read on here some people use flour? i am ready to fillet the deck now just trying to figure out how to make PB :facepalm:
mwe-maxxowner
Master Chief Petty Officer
Flour works very poorly! I used a little in an emergency situation. It acts like dough. It sticks to the spoon, putty knife, whatever. It didn't seem to adhere as well to the surfaces I used it on either. I highly recommend ordering cabosil from us composites if you can't find it anywhere else. They ship very quickly, and cabosil is cheap. Fine sawdust can be used, but I can't speak for how well it works.
KCKracker
screw it I'll just make it out of csm chopped up.
mwe-maxxowner
That takes the place of chopped strand in the pb recipe, and gives it strength, but doesn't thicken it up as cabosil or flour of some sort does. And if you add too much it makes a hairy mess and is good for nothing.
ondarvr
You can't make it with just cut up CSM. Cabosil is the key ingredient.
West Marine has it, and Fiberlay, so do many other places, maybe not today though.
jbcurt00
I again repeat my advice from your other glassing thread:
If you are on an ultra tight low cost budget, you might want to take a day or 2 and read thru some info that's been provided & ask lots of questions. Lots of questions have already been hashed thru & posted in other threads. Reading some of them may help all this stuff make more sense, be easier to follow, and ultimately, when you start working on some portion of the resto, it won't be so frustrating & you won't 'waste' materials or time.
Inexpensive, quick, easy & correct are not generally all equally available.
If you're on a tight budget, you can't afford to do it 'right', but you can afford to do it twice now, and again soon when the still less then sufficient work fails?
KCKracker
thanks, WOG just told me how and what to use so i got it down now, heading out now to get the stuff. im going to use talcum powder instead of tracking down cabosil an hour away.
Woodonglass
Just so EVERYBODY knows, I explained to KCK that Talc was NOT the ideal agent to use for a thickening agent but if he did NOT want to wait for the delivery of Cabosil and he just HAD to do it today, he could use the Talc with the understanding of it's propensity for absorbing moisture. I guess he as decided to use it.:rolleyes:
KCKracker
actually im going to seattle tomorrow to get cabosil :p
KCKracker
got the deck filleted tonight, Friday I'll be ready for tabbing and the final glass WOO HOO
KCKracker
FINALLY!! got done running half way across the state and home, last fillet DONE! now to let that cure and move her outside (fumes are killing the wife inside the house) and out in the shade and get foam in the floor, and deck glassed, then make use of these 2 gallons of arctic white gel coat :D:horn::congratulatory::cheer2::bounce:
KCKracker
WOG the spoon and mineral spirits sure beats the 3" PVC pipe i usually use, not so bulky and easy to clean off and run a bit tighter! thank you for that tip :D
jbcurt00
Probably ought to edit the text in your pix, else the pix may get redacted.....
Is that spray foam below deck?
KCKracker
there is spray foam ONLY around the fuel tank nowhere else
KCKracker
oh come now, comment on that last fillet bossman? :D
jbcurt00
Profanity isn't necessary & is against the forum rules you agreed to when you joined.
jbcurt00
Yes, your fillets looked good in the pix that was redacted. Edit the pix you posted, and then re-post it.
I'd like to see some pic of the below decks work or the thread you alluded to when you said this wasn't your resto thread.
