floor restoration
jesters420
this is my first boat 72 sea ray 200 I/O. the floor is in bad shape, i have removed all the carpet, how do i go about removing the plywood from the hull?
garrett61
Re: floor restoration
Get yourself a grinder and use the search button on floor you will have a week of reading. use a resp the fibers are nasty. <br />good luck
studlymandingo
Put on a respirator, not a dust mask, first thing. Use a small grinder for the tight spots, and a circular saw for the long runs. Set the depth of the saw to just the thickness of the floor. It is a good idea to drill a test hole through the floor first to determine the thickness. Cut it out all the way around. <br /><br />Good Luck. Read the posts in this topic heading, lots of great information here.
Flukinicehole
The first thing you should do is use the search at the top of the page.Im not trying to be a smart a$$ but 99% of my questions were answered before I asked them there.
jesters420
thanks for the help. i am starting on it as soon as i finish this. thanks again for the help.
jesters420
wow! i should have expected it, the foam is all saturated and the stringers are rotten. this is going to be more exciting than i thought! now i will have to make this as strong as i can. if this much is bad i wonder how well the motor is mounted? maybe i will be able to replace the whole thing. at least i won't have to worry about something that i have not tore apart.
Bsturkie
Jesters, I started with a small soft spot in the bow 4 months ago. As of today, I have just finished glassing in the new floor above 1 new stringer. When you start tearing out...you are going to find alot of new rot. Right now, I have consumed 3 bags of fiber cloth, 1 gallon of resin, 2 4x8 sheets of treated ply, 1 sheet of pine ply and seems like 1 million man hours and more iching than posion ivy on a bad day. But to try to answer your question, I used a 4" angle grinder with a steel cutting blade. Worked wonders. Becarefull not to grind through the hull.<br />And studlymandingo is right! Use a respirator, I used a dust mask and wondered why I was cauffing up blood! Yes, thats right. After the fiberglass grinding and sanding was over, all symptoms were gone. Anyway, fiberglass resin burns lie a bad STD so buy a box of gloves. I was more instrested in speed than safety and paid the price. As of 4/14, I was grinding more fiber in flip-flops and slipped and now have a narly gash in my toe from the grinder. The good thing is, im throwing a boat carpeting party this weekend to have other people carpet it. If you need and/or want any more tips, search this forum. Your questions have been answered 1,000 times. You can also e-mail me at jsturkie@sc.rr.com if you can't find some info!
jesters420
thanks for the advice. i have been using the respirator, it works great but the goggles i have seem to fog up so quick that i can only grind for about five mins at a time. this is nasty stuff. been reading in the foam forum, there are a lot of great opinions on whether to or not to use it. my boat is 19'6 i do not plan on taking it in the ocean. tillamook bay to do some crabbing, but mostly some springer fishing (if they open it up this year on the columbia river)some fall chinook and sturgeon. boat will stay on rivers and lakes and thats it. so should i or should'nt i?
jesters420
i have been taking pictures of where it started and my process and will put them up soon.
studlymandingo
looks like you're doing a good job so far, keep the pics updated.<br /><br />On the foam, I did a restoration a few years back and put foam only in the gunwales. The theory there is the foam wouldn't sit in water, but would still keep the boat from sinking if you swamped out.
Bsturkie
SRV, wonderful work. You are going to have a boat that you can be proud of! Shareaproject is a great site isn't it. Anyway, by now, I have the bow compartments completed and glassed. The light at the end of the tunnel is in sight. Next is carpet and seats and I'm on the water. Good luck on your project! If you make it this far south, Drop her in in Beaufort SC and we will have some fun!
jesters420
thanks for all the help. i will have pictures of my progress hopefully up by tomorrow. still have a little prep work for the floor then i will start to measure for the floor and stringers.
jesters420
jesters420
i think i need to work on this a little more, forgive me.
