Flotation foam
froggy1150
Master Chief Petty Officer
Might have been a little overkill but I wanted something that would last. Every piece of wood that was put into boat was 100% wrapped in fiberglass before Install. Then tabbed,glassed or whatever was needed
when you go to pull the motor out. pull the carb apart and clean with a can of carb cleaner. then re-assemble. that way a year from now you are not fighting with fuel residue gummed up in the carb
Jakem
As to be expected there was complete rot. The wood was not laminated together anymore and also not stuck to the fiberglass. What's there is about 3 inch thick. Is that the normal thickness I should have when I redo it
transom should be 2.00-2.25" thick
outer fiberglass (about 1/4-3/8" thick)
1-1/2" of wood
inner fiberglass
JASinIL2006
That stinks. What kind of boat are you working on?
tank1949
I have found a soft spot in the fiberglass on my floor. I have cut the fiberglass back and found rotten plywood. The foam is dry right to the bottom and zero damage to the stringer. Now is that foam supposed to be really light kinda deal as it is
Pray what you see is mildew or mold. I can't count the numbers of times in my boats that foam has soaked up water. Drill into stringer and examine drillings for black rot or water. If any, you probably are going to spend a lot of time grinding and re glassing. If not, plug holes with 5200 and thank God, you caught it in time.
nola mike
Yeah, that train left the station about 10 posts ago šŸ˜‚
tpenfield
Well, we are gonna need more pictures going forward, now that the sawz-all is coming out of the tool box.
Jakem
Here is 2...someone has patched it before in 2 different spots
Jakem
I didn't think it would make a difference beings it all had to go so the end result would be the same
Jakem
There was no inside fiberglass at all it was just wood anyways so somebody was in there for sure
JimS123
Nothing cooler than a boat with a mahogany transom with 8 or 9 coats of spar varnish. It's the classic look. Not everybody has that opportunity.
Scott06
Most go from the inside so there is no exterior fiberglass work like fairing and gel coat.you certainly can go from outside in, can paint the outside with automotive type finishes .
Pay attention to transom thickness spec Scott gave you can glass the new transom from both sides to prevent rot. My buddies glastron has exposed plywood at top, real shoddy as far as keeping it from rotting
Jakem
My outside glass looked like someone was shooting at it lol...so many holes so much sealant...I will be glassing it all ...
