Fluid for upper unit
shughes12
I just had the seal kit for the upper gearcase replaced, but now when I try to fill it with oil it just comes out the little vent above the prop. The mechanic I used has since moved across country. Looking for any advice
Ayuh,...... Is it a stringer drive,..?? or a cobra drive,..??
southkogs
Is it continually dripping out until the upper is empty? Or is the upper gear case staying full?
It is a Stringer. Looks like electric shift.
drive will need to come apart and be re-sealed.
