fluid type motor mount leaking???
kramerpage
I was cleaning up my motor mounts and noticed a small amount of red sticky fluid at the weep hole on one of the mounts at the bottom underneath the mount.
I understand these are the fluid type of motor mount. How do I know if they are good or bad. I believe they are none serviceable. These came with the boat I am restoring. I have a 89 4.3L larson with rigid mounts which is where the engine is coming from but I don't know if they are the same hieight.
1989 4.3 LV6 Alpha One Thunderbot Ignition. Engine serial 0C616538
Drive #0C735235
Ayuh,..... Use the entire transplant motor, includin' the mounts,....
If necessary, shim the mounts with wood shims,...
