flushing out a gear case.
fishfeatures
my 1990 60hp had an oil leak from the shift shaft area, so when i dropped the LU the housing where the shift shaft enters was broken and missing a chunk, how that happened i haven't a clue maybe i knocked it or something when i changed the impeller a while ago. I have a spare gearbox that suffered some external damage so I have the spare part to replace the broken one with.
Anyway, it's taken a while for the milky lube to leave the gear case and i can still see some lying around on the shift rod connector and along ridges etc. What can i use to rinse out the casing before i put the new lube in? I don't want any white milky residue at all in the case but re-filling it.
Would fuel mix do ? or hot water or something else..
boobie
Re: flushing out a gear case.
Have you still got it taken apart or are you running it ??
Chris1956
Don't use water. If it is just a touch of water/oil mix, just fill it with clean gear oil and forget it. If it is more than a touch, you could some motor oil to flush it out.
fishfeatures
I guess its no more than a touch, i just want to make sure there's no trace left inside before i refill it. Just want to have 100% good lube in there after going to the bother of fixing the broken housing.
boobie
I know I'll get some heat from this but in your situation I used to flush them out with pre-mix. Don't smoke. Years ago all we had was a gas bucket we washed off our parts in.
fishfeatures
Both of us will get grief so boobie , just rinsed it out with premix, I'll leave it for a few hours and will then refill. Cheers
boobie
I've tried that but gasoline cuts better. You just have to be careful.
iwombat
Diesel fuel and atf mix cuts through just about anything, and won't go foom on ya.
Chris1956
Gee, a touch of water doesn't merit any debate. Just refill witn new gear oil. Nothing to "cut".
iwombat
Chris, you're absolutely right. I flush mine out every few years or so, or when I get a bee in my bonnet. But a little water just needs new seals and fresh lube.
