Flywheel bolt pattern
Nick2020
I am replacing the engine in my boat which had a 1984 omc 5.7 with the stringer. I bought a used 1988 omc 5.0 engine but found that the bolt pattern was different for flywheel and coupler. Could I use the coupler that is on new engine, it is a lot bigger than original or could the original small coupler be modified?
Ayuh,..... Welcome Aboard,...... Are the splines the same,..??
Will the bigger coupler clear the flywheel cover,..??
If not, you'll need to find a pre-'86 replacement motor,.....
