Flywheel Magnets
ken_doll
One of the (6) magnets on the flywheel of my 1994 90 hp Force outboard (made by Mercury) has split into a few pieces. Not exactly sure how this happened, but I called the dealer in my area and was told the magnets themselves are are not offered and I'd have the buy the entire flywheel to the tune of ~$300.
Anyone know if I might be able to find a replacement magnet by another means? If not one specifically listed to fit my motor, perhaps I could match it up on the dimensions of any of the other 5 (every one is identical).
I'm tempted to even dremel one down by hand from a larger block if worse came to worse, but not sure how close the field strength would have to match that of the others.
Thoughts?
sschefer
Re: Flywheel Magnets
Look on Ebay, I bought several of them on there and never paid over 100.00 for any of them.
Justinde
Dont try and fix it- Frank or Jerry will be along soon with suitable replacements -i.e- a 45 HP Chrysler flywheel, a Merc 70hp etc ( dont use these). Frank & Jerry know thier stuff!!! :)
jerryjerry05
Usually trying to replace is not good.
You might get lucky,I doubt it.
Like sschefer said E-bay.
ken_doll
Thanks for the replies, guys. I glued what magnets where left back on a-la dollar store super glue and will give it a try tomorrow.
I attached a pic of what things looked like beforehand.
Any chance I could PM "Frank or Jerry" to see which flywheels might work in my application? There are some stampings on mine I wonder which would be of any assistance...
ken_doll
Luck was on my side, I guess, 'cause it worked. There's probably 5-10% of that magnet missing but she starts and idles fine, tho I haven't run it at high rpm or under load yet.
wickware
Will there be any chances of damages/danger if the magnet comes off while running? Hopefully the centrifugal force and magnetism will keep it safe. Good Luck! jow
ken_doll
Yea, that thought crossed my mind, but what could possibly go wrong with $ store glue? :D Will keep my fingers crossed and thanks.
riptorn
Lol, try JB weld if any more problems. Works great when surface prepard
