foam for flotation
rheagler
Re: foam for flotation
Most folks here use the pink foam insulation boards from HD or Lowes. Many also use pool noodles, dollar stores are best place for those. The white foam I believe tends to hold water over time. I got lucky as mine was in good shape and dry.
jigandgrub
The pink, blue, and green EPS sheet foam is the best bang for the dollar. Pool noodles are more expensive to float the same amount of weight that the EPS will.
The EPS sheet foam is closed cell and won't absorb water.
rickryder
Use the pink or blue foam board.....it's a closed cell foam just like the pour in 2 part foam.
North Beach
Just to be clear on terminology, the pink blue or green board (and I personally can't speak for the green) are Extruded Polystyrene. this is what you want to use. The white bead board (Expanded Polystyrene, and what came in many of our boats originally) is NOT what you want to use. And if you reference EPS when talking to a supplier you will be talking about the Expanded....
KRACKERMAN
Thank you thank you thank you this has been a great help
