R Socey
- Jan 9, 2011
- 501
Re: Foam or Not !
Thanks for everyones insights. The yeses seem to have it. The boat has some 70, pieces of teak, and ribbon mahogany trim. The stringers will be
marine plywood totally encapsulated in epoxi. The center flooring sections
also are marine epoxied plywood. The console is also completely covered
on the inside with same. The large fish box will be covered with styrofoam,
epoxi coated - six sides, as is the baitwell. The boat has 4, main stringers
with quite a bit of room between them, running the length of the craft.
The fuel tank is 125 gal. that will only be filled to maybe half the capacity
because of ethanol fears. The gunrail has some space for foam as well. I
don't know if it will float in a catastrophe, but I guess I'll fill every void I
can, and hope I never find out. I greatly appreciate everyones input. I'll
be sure to post pictures when the economy, and weather warms up.
