Hello all i have a 1979 35 hp johnson model 35el79a. I've had it for 5 years and it has been a very reliable motor. Recently it started caughing and idling very rough. I ran some seafoam through it and it helped but then it got worst to where it would die after running at wot. I waited about 30min and it started right up but would only go to half speed at full throttle. I decided to rebuild carb and now when i run it on muffs i noticed this foamy oil coming from exhaust at prop. I thought it was from lower unit so i removed oil and it was normal but when i removed lower unit i found this stuff. Any idea as to what would cause this or how to fix it?
