for the IT guys at IBoats
Bt Doctur
When responding to a post, it just sits there and says working, if you hit the refresh symbol ,the message posts.
If you click on a post and go to open in another window, when done the post is still there. the window dosent close
The "back arrow" dose not work ,you have to go to Mercruiser I/O & Inboard Engines & Outdrives and the page will refresh
alldodge
I also noticed many of the post I make I'm not getting any post points for
Bt Doctur
A new glitch, after you answer a post, it dosent show your SN making a post.
dubs283
i also have noticed that personal post counts do not go up, hopefully they will add to total posts after all the glitches are fixed??
Bt Doctur
OK, the back arrow is working again.
responding to a post dosent show up but your answer is posted.
cant delete message file or trash files
posts made are not added to the post count under your sn
Bt Doctur
"post reply" hardly working, need to
Fishermark
I understand things change. I also realize that anything new often comes with "glitches." BUT.... :eek: This "upgrade" is almost unusable. Is there a light at the end of the tunnel yet??
Ayuh,..... I'm told there Is, but I can't see it yet,.....
Ayuh,..... Damn,... My lead is shinkin',.... :lol:
Walt T
Whew! I thought maybe they were "carefully examining posts from that weird walt guy"
Starcraft5834
Im not sure I would characterize the problems with this upgrade as "glitches"... that's being very kind...........puzzling how IT would put out this product in this condition.. what the heck.... Edit: Political ... :eek: I guess iboats gets a pass on this one
southkogs
My count is going up, but it's going up when the page is refreshed, not when I put the actual post up. I've seen a couple of new guys with post counts of "0" on their second post, so there is something going a little goofy.
GA_Boater
We also lost the speedy response like we had last night, Kogs. Maybe they switched back to
NOGREATATALL_zpse2d032c4.jpg%7Eoriginal
:smile:
