Re: Force 120 Powerhead
It should also be noted that when rebuilding either a replacement powerhead, or the original, you will have to be able to be precise in measurements made regarding the cylinders, reed valves, and crank alignment.
Take your time and do it slow if you choose the overhaul route.
