Force 120 Prop Hardware
Josh P
Hey all, i bought a boat with a 1991 force 120 on it it runs great. Boat needed some work but it was a good pricel. The prop was stolen off the motor before bought it. I need to know what hardware i need? they were noice enough to leave the rear thrust washer what do i need from the prop forward? of course i know you need the prop to start with.
HAV2FISH
Re: Force 120 Prop Hardware
After cleaning and putting a light coat of grease on the prop shaft. Put on the thrust washer, prop, prop nut cup (thats what i call it), then prop nut. Tighten the nut and the nut cup together. Bend three tabs down from the prop nut cut to fit in the slots on top of the prop. Tighten to just snug. The nut cup keeps the prop nut from spinning off.
Josh P
thanks for your help, do you know where i can get this stuff from?
Josh P
thanks but they dont list the splined thrust washer for it just a nut kit. let me ask this why do they include 2 washers in the nut kit, didnt really see a difference. Thanks again evryone Would also want to know what type of oil for the lower unit? thanks
