Force 120 ELPT, 1997, ID OE275799. We have this on a 24' pontoon boat. It starts fine and idles ok. Will go to 3000-4000 rpms and run fine. If you give more throttle, it hesitates, chokes back and goes to slow speed. Then it will surge a little and hesitate again. I usually pull back to idle speed, give it a moment, then go back to 3000-4000 where it runs fine.
I put a new primer pump on. It never gets hard when I squeeze it up but you can see fuel flowing through the clear glass filter and it starts right up. Not sure if it is going flat when the hesitation occurs. Never tried to squeeze it while trying to run at full throttle.
The fuel lines are about 2 years old and don't show any cracks or fuel leaking anywhere. They appear tight.
There was some leakage from the front of the float bowls when motor was trimmed up. I put in new float bowl gaskets and there is no leakage when motor is running while trimmed all the way down in water. Still have slight leakage when trimmed up. Have read in this forum that this leakage is normal so guess that's not the problem.
Have been considering rebuilding fuel pump but not sure if that's the right thing. Would prefer to save the money and do it myself but am close to calling the boat mechanic. Problem is , what to do? When the grandkids are in the tube hollaring "faster, faster", I like to oblige. Very disappointing when we can't get over 3000 rpm. Will greatly appreciate any advice!! Thanks!
