Hello guys! So, long story short, my lower end fluid was a little low and my upper drive shaft bearing took a poop on me. I was lucky and nothing got damaged, it didn't "grenade" or anything like that, just seized up. I got the lower unit off and I got that retainer off as well as the outer race, cage and rollers of the old bearing. So, I just need to get the inner part of the old bearing off in order to put the new bearing on. Obviously, I need to remove the drive shaft to do so, how do I go about getting it out?
capture
#9 is what I need to replace. No one around here will touch a Force, apparently they're the outboard equivalent to the plague....
capture
