grininmonkey
- Aug 26, 2008
- 35
While I work on my piston issue, another question I have is related to the fitting of the prop. When I bought the boat, it came with two props one is a 15 pitch and I don't know what the other is (no markings). They both have shaft play and I worry that they may be the wrong props even though I can tell one has been used for a very long time.
Is it normal for (with the prop nut tightened as far as possible) the plastic spacer flare to be loose and able to move the prop back and forth on the shaft a good bit. I tried fitting both props and they fit the same with the spacer flare having a lot of loose play. The prop nut is tighten as far as possible and all washers/etc are in the proper place. I didn't measure it, but it seems to be close to about 1/4 inch of play or movement... meaning, if I push the prop & spacer flare against the thrust washer and then move it away from the thrust washer a quarter inch before it makes contact with the prop nut / washer. I can move the spacer flare away from the prop a bit, etc...
My previous experience with outboards used a prop with the flare as part of the prop and never had play/movement on the shaft, the prop was flush against thrust washer and with the nut tightened the prop would be secure against the thrust washer leaving no play. So having this two piece setup is new to me and not sure if I am suppose to be able to move the prop/spacer flare like I can?
