erosenwinkel
- Apr 22, 2011
- 130
1258x5a (1985 125hp) Had what I thought was ignition switch problem. 30% of the time the ignition switch would not send power to starter. Changed switch (13 bucks). Still have same issue, maybe only 15 % of the time. I put a new solenoid on it before the switch. Starter always works when I jump the solenoid with a wire. Seems to never have problems with a cold engine. Battery is good. Guages and push to choke are not affected. Engine starts right away, very little cranking if any. The solenoid is not original force/merc product but simply one I picked up at Farm & Fleet, an ag/automotive type of box store. I am thinking maybe the solenoid gets warm from the engine and won't operate when warm? Any suggestions? This is a pain when I have to restart the boat on the pitching water and slip the cowl back over risking a meeting with the flywheel.
