dknightfish
- Mar 17, 2013
- 7
I have a 1988 Force 125 Outboard. After my first trip out this year I found water in the lower unit. I dropped the lower unit and ran a pressure check several times with 10-15 psi. I did not let it sit over night, but I soaked the top end around the water pump with soapy water and the prop shaft seal behind the prop and could not see any bubbles or hear any leaks. The only problem I could see is some of the rubber on the back of the prop seal is cracked and missing. I did hit a rock and bend one blade on the prop, so maybe that damaged the prop seal. I would try a vacuum test but don?t have one of those.
Since the prop shaft seal shows some wear I figure I will start there. My question is how far do I need to disassemble the unit to change this seal? Do I have to take the forward gears out and everything? My goal is to start with the easy seals that would most likely fix the problem, and avoid taking the whole thing apart if I can. It runs and shifts smooth so I don't really need to inspect the bearings and gears, just get rid of the water in the oil.
Thanks for any suggestions.
