There is a special tool to install OEM piston wrist pins. The keepers should be very close to the piston lands and the wrist pin should have none to very slight lateral movement. The OEM wrist pins are a slight loose fit to a slight interference fit in the piston. Since , if you have a Force engine the top ring is a semi-keystone ring and since these rings do tend to catch in exhaust ports and break and since you already need to buy rings for it, you would be better off buying another Wiseco piston.
However, the choice is yours and the engine will not know the difference between pistons.
