Compression is 120 in both cylinders. The plug in the bottom cylinder was fouled (wet) With the spark plug's out I removed the fuel line to the carb and ran a test hose from the fuel pump to a coffee can. Spun the engine with the starter and no fuel came out of the hose. But if I squeeze the fuel bulb at the tank I get fuel to the coffee can. Is this normal, does the engine have to be running for the fuel pump to work. When squeezing the bulb you can hear the fuel being pumped but the bulb never gets hard. I have new fuel in the tank and the vent open. I have low power, hard starting with the engine warm. Any ideas?
What is the plug gap for this engine? Is there a way to test the coil packs, besides putting your tongue on the plug wire and spinning the engine
Thanks all
Thanks all
