Re: force 90 dies under load
As was answered in your other post:
Do you know how long it sat since it was last used?
Did you have the drive unit in a tank of water when you ran it?
Or on "water muffs" ?
Or was there no water at all when you started it on the trailer?
Several things come to mind.
1- one of the sparkplugs is not firing
2- one of the cylinders has low compression
3- carburetors are gummed up and running lean
4- fuel pump is going bad
5- vent on gas tank is plugged
At this point, we need to eliminate some of the possibilities.
You need to check to see if all the sparkplugs are firing.
And examine the plugs to see if they all look the same.
Then check the cylinders for compression. Post the compression readings here.
Ask here if you are unsure of how to do any of these things.
You still have to determine if it is a fuel, compression, or spark problem.
Then we can get to work on the solution.
Take eurolarva up on the offer.
Take your boat over to him and let him help you out.
He needs something to do.
