force engine
ADAM$$$$
i bought a 1987 bayliner and brought a 87 force engine but it not running 125hp what can i do without spending alot of money
TwoFish
Re: force engine
Do a compression test to make sure the cylinders are ok.
Inline spark tester to check ignition.
catfishcarl99
Re: force engine
indeed. if compression is bad then find another motor. or spend lots of money. if thats ok move to spark and clean carbs replace impeller and crank it over. fresh gas too.
ADAM$$$$
Re: force engine
Ya I have check the compression and it 120 psi on each cylinder and spark plug and inline
Jiggz
Re: force engine
So do you have spark in each of the spark plugs? If yes, then all you need is to make sure you have fuel and that engine should run. You might have to clean the carbs or at least disassemble the bowls to check the floats. Do you know if it has fuel going thru? If not sure crank it over and smell the exhaust it will tell you if you have fuel going into the cyl.
