Force lower unit
cdn3700
I am about to remove my lower unit and would like to get some information on how to remove it where it will hook back up the way I took it off. Also should I change the empellor when I fix the stripped oil screw while I got it out and is there any secrets I should know? You can email me at cdn2700@yahoo.com or message me at cdn3700 on yahoo messenger or cdn37001 on msn messenger. I would appreciate any feedback. thank you
Re: Force lower unit
Im new to this kinda thing but we have a 1989 force motor. So far we're having a problem with water circulation. The most popular reason for this is impellor. because its made of rubber it can get brittle and break down, also the tips of the blade can bend making it difficult to get proper circulation. If i were you i would at least take a peak at it, it might save you alot of headache later
roscoe
If you haven't replace the impeller in the last year, do it !!
