ford ranger
sea wolf
opinions needed on the ranger as a tow vehicle. i'm looking at an xlt with a 6 cyl. auto. boat weighs approx. 3,000 lbs.
crab bait
Re: ford ranger
WRONG BOARD.. DOESN'T BELONG HERE.. your not a 'rookie' & should know better ... take it to nothin' to do with boats board....
dhammann
Re: ford ranger
Don't be a crab, Crab bait.... the guy is asking for help. Let me give some southern hospitality,<br />sea Wolf, what distance and terrain will you be pulling your boat? You definitly need trailer brakes since the rig weighs as much as your truck.<br />I pull the same wieght with a 4 cylinder S-10, slow but sure.
sea wolf
Re: ford ranger
crab bait, take this to the other board & since when are u the moderator? talk about anal retentive. big dee, thanx for reply. i'll be towing approx. 25 mi. one way only a couple times a season as boat is kept on a slip.
Bob_VT
Re: ford ranger
Don't be so vicious with your comments (never burn a bridge you may have to cross someday) to Crab Bait. Me personally, I consider this a towing question ;) <br /><br />Your book answer is Ford Ranger 3.0L V-6 towing capacity Manual Trans 2200-2640 lbs and Auto Trans 3680-4100 lbs. Opt for the 4.0L V-6 and it is manual 2740-3560 and auto 5200-6020 lbs.<br /><br />Toyota Tacoma 5000 w/V6<br />Dodge Dakota 3500-6450 w/V6<br />S-10 4400-5800 w/V6<br />Nissan 5000 w/V6 <br /> <br />Of all listed the Nissan has the best resale and is not over rated. The other companies tend to inflate the values. This takes into account that an auto transmission is torque multipling. <br /><br />Bob :cool:
JB
Re: ford ranger
CHEESE!!!<br /><br />I go away for a few days and you guys are acting like 12 year olds!<br /><br />The question belongs in trailers, but here is a good second choice.<br /><br />A Ranger? 3000lb? NO WAY! Get a F150. :)
rickdb1boat
Re: ford ranger
JB<br />You've got the answer! I tow about 2000 loaded and had a Ranger with the 6 cyl. It was tough to tow the load with that! I now have a F150 W/ the 5.0. Nice and easy now!
dhammann
Re: ford ranger
since you pull it so infrequently I would not spend the money for a gas guzzler. I share a similar situation with my S-10, have been doing it for 7 years and 85,000mi with out any problems at all. I live 40 miles from the lake and leave my boat there but pull it home to service and clean 10 or 12 times a year. Since I don't have a boat slip I have to use my truck every time I use the boat...3 or 4 times a week! Invest in some trailer brakes, they are faily inexpesive (Nothern Hydraulics)if you do it yourself. My first prioity is 27mpg since I use the truck more for work than pleasure. The money I save goes for more boating pleasure. Ford Rangers are tough little trucks.
