bassman284
- Jun 24, 2006
- 2,840
Re: Ford Spark Plugs?
Yeah, I'm old enough to be leery of putting Champs in a Ford but wonder if maybe electronic ignitions get around the problem. Used to be that was a good way to end up a pedestrian.
The problem was with the early 3 valve 4.6/5.4L/6.8L engines. From '04-'08 (according to the Ford TSB). Ford revised the head/spark plug design for the latter engines.
Current owners have to resort to changing there plugs sooner than the recommended service interval if they want the plugs to come out in 1 piece. I have read where Champion has come out with a 1 piece plug for these engines... I would have mixed thoughts on installing a Champion anything in a Ford, but I suppose if Champion engineered the plug directly for this application, it would hopefully be better than reverse engineering heat ranges/thread size to make a Champion fit in something not intended to use a Champion....
