sublauxation
- Oct 13, 2008
- 1,317
Not sure where to put this but I hope somebody can help. I have an 04 Expedition and when I hit the brakes really quick the pedal falls to the floor. It pumps up quickly, then acts normal again.
There is no brake fluid leaking. I bled the brakes and had a hard time getting anything out of the rear driver side caliper. The first couple times I cracked the bleeder nothing came out, and the pedal only went down a little with firm pressure on the pedal. I finally got a little air spurting then got a couple solid streams of brake fluid. The other wheels all bled as normal. I took the truck for a spin and when I hit the pedal it went to the floor again. I tried bleeding again and the same thing happened. I bled about a quart of fluid through the system.
I'm guessing it's either a caliper or the rubber hose to the caliper , but wondering if anybody else has any thoughts. With the wheels on it looks like the pads are wearing evenly in back, but I haven't taken them off to have a closer look. Everything seems normal with regular driving. Thanks for any help
