- Jul 23, 2011
- 51,141
dont confuse the external marine bolt-on parts with the internal GM parts.
the long-block came from GM. other than the cam, brass core plugs, stainless head gasket and the marine circulating pump, the motor itself is a truck motor as those found in an S-10 or a C1500
the accessories on the front of the motor, the carburetor, the ignition system and starter were bolted on by Mercruiser along with the marine exhaust manifolds.
Mercruisers at the time bought many of their manifolds (both intake and exhaust) from Barr, and they made their own ignition.
if you want to identify the exact year of your motor, read this https://forums.iboats.com/forum/eng...history-of-the-4-3-liter-with-casting-numbers
if you have 1989 motors, you have a non-balance shaft 4.3 with a roller cam
this is the part you are changing in addition to the exhaust manifolds. you should be able to keep all the rest of your accessory drive stuff and just move it over, especially if your replacement motor is a 1988-1991 vintage motor.
In 1992 they added a balance shaft, in 1996 was the vortec heads
