- Jul 18, 2011
- 18,552
I cannot get to the other side of the stringer at the back. Formula boxed the very end and installed the hatch lift on one side and the power steering pump on the other. Would a straight butt joint be the way to go or do a 45 degree or something else?
You may want to remove and then rebuild the boxed ends of the engine mount stringers. That will require some additional 1/2" plywood and some 2-part foam (4 lb density).
The key thing at this point would be to determine the extent of the repair area, based on what you find in terms of moisture and rot. It may take you past the engine mount stringers and to a point before you reach the outer stringers. Some of the wood that shows in the pictures is still dark, so you could rationalize going further outward until you reach blonde wood.
A judgement call on what you replace versus what you chemically treat. In my repairs, I have done a bit of both.
