Formula 330 SS Head Liner Refubishment
tpenfield
I noticed that the headliner cloth was hanging down at the end of last season. The cloth seems to be separating from the foam backing, etc. So, I planned to do a little bit of work on it as part of the prep for this season. My plan is to remove the center section of the head liner and rebuild it using the existing foam and cloth. Today I started into it . . .
The headliner is mainly held up by screws that are under the light fixtures IMG_5900.jpg
I am not sure what the 'proper' procedure for removing the headliner, if there is even a proper way to do it, but my plan was to take out all of the fasteners and then pull it out from the side where it is clamped somewhat by the restroom and electronics panel.
I had to cut the light fixture wires, as they were not on connectors, just crimp splices. IMG_5903.jpg
After a bit of tugging and various gyrations, I got the head liner to drop down IMG_5908.jpg
* * * continued on next post * * *
tpenfield
Here is the headliner (center section) in my living room for the evening. I plan to refurbish it outside tomorrow, as the weather will be dry.
I took the opportunity to check out the wiring runs, as I plan to add wiring for a windlass (to be installed next year - maybe)
The outside sections look OK, so I will leave them alone.
To be continued . . .
muskyfins
Wow. That's some undertaking. Mechanical I've got. But upholstery is a pain. Bravo.
Waiting for more updates on Monday.:pop2:
tpenfield
Thanks. :)
After a bit of inspection and some dis-assembly, it looks like I will need to get new headliner material. I was hoping that the foam backing would be in decent shape and re-usable, but that is not the case.
I also have noticed that the headliner is made up of 2 pieces of 1/4" plywood, bonded together with a 1/2" ply backing piece. To make re-installation easier, I plan on separating the headliner at its joint and installing it as 2 sections rather than 1.
I will make the 1/2" backing piece part of the wider section and then use a couple of screws to attach the longer section during installation. Even though these screws, will show, I think it will make installation so much easier.
Now the search for headliner material. . . It looks like this project just went 2X on my original expectations :rolleyes:
tpenfield
Quick Update:
I ordered a sample board from an auto trim supplier. None of the colors matchd exactly, but the old material being almost 20, I figured that may be the case. So, I ordered the closest one. . . "PH1747 - Quicksilver"
Probably will be finishing it up during the first weekend in May.
bigdirty
Yup, that looks like it will be a bit of a job, but it will look good in the end I'm sure. The clean look (no fasteners showing) is nice, but would defiantly make it more difficult. I for one don't mind fasteners showing, if they have proper eyelets and are spaced even/symmetrically in some way. And I'm all for "ease of assembly" too..
Surprised ur boat didn't come with a windless from the get go.. That must be a bit of a walk to get to the bow on that ship.. :laugh:
tpenfield
Yea, this is the early model of the 330 series, so not all the boats had the 'goodies'. I'll be happy to have it all installed . . . tired of going up the the bow to pull the anchor.
bigdirty
Ya, my friends 1994 31pc has the factory windlass, very handy indeed. Mind you, his doesn't have a walk through windscreen, and the side walk-around isn't much bigger than my little 250 crownline... somewhat death-defying even getting around the radar arch in fact... so might be that they deemed it a necessity for his model, which is still a 34' overall boat.. shes not small :lol:
tagging along as I may soon have to tackle a similar job
tpenfield
Some Updates . . .
My headliner material should arrive early this coming week. This weekend, I did some prep work on the headliner, and will probably do the installation next week.
Here are a few pictures . . .
I terminated the wiring that I had to cut for the lights. So, going back in, they have connectors instead of hard wiring.
I removed the old headliner material and the deteriorated foam . . .
I separated the headliner at the seam. Lots of mold on the forward section.
Here is the rear section, which will carry the backing piece that the forward section will screw into . . .
Here are the pieces after a bit of bleach to clean them up . . .
Everything is ready to go for when the material arrives. My hopes are separating the one large piece will make installation much easier..
Corjen1
Good work so far! Tagging along if you dont mind.....
tpenfield
The material arrived today . . . sort of wish it came a day earlier as I would have been able to knock this off over the weekend. Looks the same . . . maybe a bit darker than the original.
tpenfield
Well I'm looking forward to the renovation!
Welcome aboard. . . I'm looking forward to completing the headliner, as so far it has been the easier of my boat projects. Of course now that I said that watch all heck break loose. . .
kcassells
I have a lot to do in my little cuddy/berth from scratch to final so watching and learning as we all do will be a great benefit.
tpenfield
Update:
I finished off the headliner today. I was quite a bit of work installing it into the boat . . . overall I would put this project at an 8 on a 10 scale. Here are some pictures of the day.
Cutting out the material for the headliner sections
I used spray adhesive on the headliner board and the material backing
Then it was a matter of adhering the piece and making the cuts for the curves and corners.
Here is the finished piece. This is the rear section.
Here is the forward section all done up.
I did a bit of cleanup in the cabin on the side headliner pieces.
Continued on next post . . .
tpenfield
Here is the rear section installed. Things were getting difficult at this point.
Another view of the rear section
Here is the forward section installed, along with the lights, etc.
The seam looked OK, and the 2 screws that attach the 2 sections seems fine too.
At some point, I'll probably need to replace the remaining headliner material . . . but that can be a project for another day.
zool
Looks real good Ted, the slight contrast in color looks like it was always there...
tpenfield
thanks . . . I could not find an exact match, so I went with the closet thing. The color contrast looks OK. I'm not sure if the original material faded in color, but if I re-do the rest of it, I'll use the new color.
