- Jul 18, 2011
- 18,285
regarding the foam stain on the gel, have you tried to remove the foam with a razor blade and buff? not sure what you can use to get it out of the vinyl. if you find something, let me know :facepalm:
fuel consumption is a bit high, however if your pushing winds and going against the chop, that would be normal. Especially if your just lumbering along at displacement speed.
most importantly, was the cooler full?
Hey Scott:
It seems that I got one of the 2 parts of the foam on a few spots (not the catalyzed foam itself) Looks like it is the darker colored 'part', which I believe is the 'isocyanate' part (nasty stuff) . . . It seems to be dry/cured . . . or perhaps just left a stain. I did a little bit of searching on the web and it seems that MEK might be the next thing to try. Acetone works if used right away, but does not seem to do anything afterwards.
Fuel consumption is about 1.4 - 1.5 mpg . . . which is about right for that boat. Of course, I have no precise way of measuring.
Cooler was full . . . at the start of the day . . .
