- Jul 23, 2011
- 50,623
Re: Formula 330SS Bulkhead Replacement
we should get the USCG circular into the adults only stickies
Hey Ted! I just noticed who the author of this thread was and thought I'd pop in for a looky see. I've been wondering if you were ever going to do anything substantial about these problems besides your "white witchcraft" with the holes, antifreeze, vacuum cleaner, and heaters.
1. Since the rot in your stringers seems to be in small isolated areas, I would "skin" (cut and remove) the fiberglass off of the area with a decent lap on to good wood, then I would drill out the rot with something like a 1" auger bit in a "honeycomb" pattern. Let the wood dry and fill in the voids with a thin epoxy like the USComposites 635, let cure and then glass everything back in.
2. The fuel tank dilemma is a booger bear! Wet foam/trapped water against unprotected aluminum causes galvanic corrosion... and that aint good! I also suggest removing the tank and painting it, then reinstall with a 4 lb. density expanding urethane foam. The 4 lb. foam is much more water resistant than the 2 lb. density.
I don't know if you've already seen this or not, but it's a USCG circular on Underwriter Laboratories research and testing of below deck metallic fuel tanks:
http://www.uscgboating.org/assets/pdf/recalls/BSC79.pdf
I didn't catch that the tank had been painted, but the paint came off w/ the foam.
As foamed tanks go that have foam showing water intrusion, that tank still looks pretty good. Perhaps Formula did a better job then most protecting the tank at original install. Not an easy choice, leaving it or pulling it. Good luck either way............
Always a great plan ^^^hopefully get it back to the way it should be.
Things to consider...
1.) World Peace...
2.) Universal Health Care
3.) Early Retirement
4.) 100% All composite Boats
5.) What do Women REALLY WANT???
6.) Who REALLY shot Kennedy?
7.) Did we REALLY walk on the Moon?
8.) Where does the Wind come from?
9.) Why can you only find 1 Sock?
10.) Why is Ice Cream in a Dish called a Sundae instead of a Saturday?
I think you, Zool, GWPSR, tboner7864 & bigdirty are the only 'big' glass boat builds I can think of. Except your's, they are all sub 30ft, and are mostly gut & rebuild.
If anyone can say one thing about Formula is they do make a heavy boat. As your pulling the foam away from the sides if you find it is localized to just the one or two areas, may decide to rethink the total removal. If the tank is held in solid except for the couple areas maybe prime, paint and re-foam.
Have you decided on what you will be painting the tank with yet?
